Ford 6.0 won't run
Old Jul 6, 2014 | 11:45 AM
Wyattvt's Avatar
Default Ford 6.0 won't run
Hey guys I'm new to this site and have quite the project on my hands. Recently I purchased a 2006 extended cab long bed 4x4 lariat 6.0 at an auction for 1800! The bad news it was a DNR but with a flatbed and near new tires I figured I couldnt go wrong at that price and drug it home. After installing new batteries I found the odometer reads 93k
The problem I found is when I crank it over it smokes like a freight train, but acts as if it wants to fire but can't quite fire. Popped the oil filler cap and cranked it over to discover tons of blow by. I also discovered upon taking the intake apart in search of the oil leak around the turbo that the turbo was hard to spin. Would the turbo cause me these problems? Help what are my next actions!! Advice much appreciated
Thanks, wyatt
Old Jul 8, 2014 | 03:06 PM
Just-Another-Dieselguy's Avatar
Does it Start and run on ether?
Old Jul 8, 2014 | 05:39 PM
turbo2332's Avatar
blow by while cranking. big holes in pistons.
the truck needs plugged into a labtop and many perameters looked at. diagnosing one of these isnt quite as simple as earlier models. give us the codes. buzz the injectors. if it starts whats the power balance. IPR %, HPOP readings. you need 700+ to start. no the turbo wont make it not start. it can throw things in a limp when its running but wont keep it from starting. if all this fails do a compression test, which is wear i lean due to your comment about blow by.
Old Jul 10, 2014 | 12:34 PM
whattruck's Avatar
What color smoke ? White like in steam, black like diesel or blue like oil.
Also the smell of the smoke can help.
Old Jul 10, 2014 | 09:47 PM
Adrenaline junkie's Avatar
Tons of blow by could be stuck rings if it's been sitting a long time or a hole in piston. I would put a scanner on it and do a compression test on all 8 cylinders
slowstroke
For Sale
Apr 1, 2015 11:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
dunruh
Nov 27, 2014 07:57 AM
