Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Duramax LBZ
Old May 1, 2008 | 12:23 PM
DB Admin's Avatar
Banned
Default Duramax LBZ
The LBZ is nearly identical to the LLY engine. It is a 6.6 L turbocharged engine and was introduced in 2005 for the 2006 and early 2007 model years. Its output is 360 hp (268 kW) at 3200 rpm and torque is 650 lb·ft (881 N·m) at 1600 rpm. It's mated to a new Allison 1000 6-speed transmission.
The following trucks have or are due to have the LBZ engine:
  • Chevrolet Silverado HD
  • Chevrolet Kodiak
  • GMC Sierra HD
  • GMC TopKick
  • 2006 Hummer H1 Alpha
  • Chevy Express full-size
  • GMC Savana full-size
Specifications
  • Engine Code: LBZ
  • Displacement: 6.6L / 403 in³
  • Bore x Stroke: 4.06 in (103 mm) x 3.90 in (99 mm)
  • Block / Head: Cast gray iron / Cast aluminum
  • Aspiration: Turbocharged & Intercooled
  • Valvetrain: OHV 4-V
  • Compression: 16.8:1
  • Injection: Direct; Bosch High Pressure Common-rail
  • Power / Torque: 360 hp (268 kW) @ 3,200 rpm / 650 lb·ft (881 N·m) @ 1,600 rpm
Old May 1, 2008 | 02:45 PM
94Matt's Avatar
Posting confusing information to get threads going are we?
The LBZ shares very little with the 04+05 LLY, 06 LLY is virtually the same as the LBZ with programming being the only difference.
Old May 1, 2008 | 03:20 PM
Rttoys's Avatar
This is true. If you did any real research you would find a huge difference between the '04.5-'05 LLY and the '06 LLY- and LBZ (mainly in the cooling system).
Old May 1, 2008 | 03:30 PM
LeadfootDuramax's Avatar
Basically, if you have the 6 speed Allison, you have the LLY that is very very similar to the LBZ.
Old May 1, 2008 | 03:43 PM
malibu795's Avatar
x2 ECM are different
and the LBZ turbo is SMALLER then the LLY turbo
lly turbo is a VVT variat of garrrets GT4088
88mm wheel with a 64.5mm inducers that is the lly turbo
LB7- Compressor:
Inducer 59.9mm
Exducer 82.0mm
havent found the spec onthe lbz turbos yet
Old May 1, 2008 | 03:55 PM
Because they are top secret special turbos
Old May 1, 2008 | 05:02 PM
malibu795's Avatar
Old May 1, 2008 | 05:03 PM
redneckbuckeye's Avatar
Good info
Old May 1, 2008 | 08:42 PM
You are just jealous admit it
Old May 9, 2008 | 08:49 PM
dozerboy's Avatar
Lower compression/pistons
Grid heater
Different block
and???
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
duramaxtuner
Dec 10, 2014 01:24 PM
