raptor 100 issues?
Old Jul 1, 2014 | 10:32 PM
4x4kingx889's Avatar
Default raptor 100 issues?
I have a 01 which is all stock I had the BD diesel early warning light and seen it started to come on so I replaced fuel filter and no help I parked the truck and order a fuel pressure sender for my quadzilla adrenaline ( really only use this as a gauge set got it cheap ) thinking the BD warning light was bed gauge was reading 5 psi at idle and dropping with revs! I tried adjusting the regulator on pump but doesn't seem to do anything the pump is only a year old with little use installed it same time I installed vp-44 and one have any idea's?
Old Jul 2, 2014 | 11:20 AM
vineyardm's Avatar
You should do more troubleshooting. If you get the 5 psi warning light - did you do a check to help determine if actual pressure is low (pointing towards lift pump problem - or some obstruction in fuel lines or fuel filter).....or if your pressure sensor might be faulty? Have you verified your LP is working properly? (Even a fairly new LP can die ...so don't assume it can't be a problem because it is only 1 year old.)
And while you are at it...consider upgrading your fuel lines - get rid of all banjo bolts and go to something like Vulcan's "Big Line Kit" ....helps ensure adequate flow to the IP - assuming the LP isn't having problems.
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
Apr 11, 2015 02:47 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
