Duramax LB7
Old May 1, 2008 | 12:21 PM
DB Admin's Avatar
Banned
Default Duramax LB7
The LB7 was the first to be introduced in 2001. The V8 engine is a 6.6 L (402.8 cu in) and it has 300 hp (224 kW) and 520 lb·ft (705 N·m) of torque. It is a 32-valve design with high-pressure common-rail direct injection and aluminum cylinder heads.
The Duramax was on the Ward's 10 Best Engines list in 2001 and 2002.
The following trucks use the LB7:
  • Chevrolet Kodiak/GMC Topkick
  • Chevrolet Silverado/GMC Sierra HD
Specifications
  • Engine Description: LB7
  • Displacement: 6.6L / 403 in³
  • Bore x Stroke: 4.06 in (103 mm) x 3.90 in (99 mm)
  • Block / Head: Cast gray iron / Cast aluminum
  • Aspiration: Turbocharged & Intercooled
  • Valvetrain: OHV 4-V
  • Compression: 17.5:1
  • Injection: Direct; Bosch High Pressure Common-rail
  • Power / Torque: 300 hp (220 kW) @ 3,100 rpm / 520 lb·ft (705 N·m) @ 1,800 rpm
Old May 2, 2008 | 01:28 AM
2500HeavyDuty's Avatar
Yup
Sep 7, 2015 07:30 AM
Bamafantrey
Aug 24, 2015 09:30 AM
duramaxtuner
Diesel Engine Conversions
17
Jun 1, 2015 10:41 AM
Oleoleson
Mar 28, 2015 06:20 PM
duramaxtuner
Dec 10, 2014 01:24 PM
