12v cummins bad oil leak please help!
Old Jun 27, 2014 | 11:01 PM
RoughneckZach's Avatar
Default 12v cummins bad oil leak please help!
Okay guys this is my problem truck runs great doesn't miss a beat driving around town doesn't leak drop of oil but if I get on the highway and drive for a little while massive oil leak covers everything and gets on the tail gate and bumper the right side of the motor is covered and the passenger side is spotless. I have it narrowed down that it might be coming from somewhere around the injection pump. I ran the truck around town for a little while and let it idle in my driveway for a good hour all it had was normal 12v drip nothing more has anyone else had this problem?
Old Jun 27, 2014 | 11:37 PM
Okay I think I found it a bolt was missing from the afc and the other I could move with my fingers but it got to late and I couldn't test it would loose afc cause this problem?
Old Jun 28, 2014 | 12:29 AM
detroitdiesel idi's Avatar
I wouldnt think so check tappet cover gasket on driverside behind inj pump
Old Jun 29, 2014 | 03:48 PM
Green Gobblin's Avatar
x2 on the tappet cover. Also check your oil feed lines to the pump and the vacuum pump.
Old Jun 29, 2014 | 08:48 PM
six speed's Avatar
there is also a plug into the main oil galley. mine wise leaking. It's right under the tappet cover.
Old Feb 21, 2015 | 12:00 AM
Str8sixpack's Avatar
Sounds like carry over. Bet that oil is coming from the blow by tube. Burnt up turbo bud
Durtyd09
Nov 11, 2015 01:43 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
ash23k
Dec 30, 2014 08:31 PM
coors_man_2005
Dec 15, 2014 10:23 AM
