how to wire a obd2 to a 99 cummins ecm
Old Jun 22, 2014 | 11:01 PM
Ladder2281's Avatar
Default how to wire a obd2 to a 99 cummins ecm
I need some help on how to wire the obd2 port to the ecm on a cummins conversion
Old Jul 2, 2014 | 11:29 AM
vineyardm's Avatar
You might want to provide more details and explain what you are trying to do.
In general - the Cummins ECM has a CANBUS ....and it also has lines that go to an OBDII 'port' to allow readers to access the engine data and fault codes. If you find and download a typical shop manual that includes wiring diagrams, you will see what lines from the ECM connect to the OBDII port.
Many people will use the OBDII port to connect something like a SCANGAUGE and provide real time display of various engine parameters, and the SCANGAUGE can also display a better estimate of MPG than the overhead reader that some trucks came with. And of course, the OBDII port is used with scanners to read faults, or to reprogram the ECM.
The CANBUS connector (near the ECM, near the fuel filter) might be used for certain programmers - like the EDGE EZ - to modify timing.
Old Jul 3, 2014 | 11:35 AM
Ladder2281's Avatar
Thanks. I got all wires hooked up but the scanners will not link up. I am trying to see if I got any fault codes.
jeremiah1
Jun 18, 2015 05:01 PM
Zachbishop
May 29, 2015 07:21 PM
Lanceomni
Feb 23, 2015 09:26 AM
DSM1988
Jan 25, 2015 07:23 PM
PerformanceAuto
Jan 15, 2015 12:32 AM
