12v cummins 400-450hp
Hello
I have a 97 12v
the pump is tuned up a little (other owner)
it is a stick with a upgraded clutch (don't know what clutch it is)
i want to get 400-450 hp and have it just as reliable.
i know that i prob. need a bigger turbo (what would you suggest)
also what injectors, and pump tuning
also would it be smart to put on water/meth injection
do i need to change the head gasket and bolts/studs
the KDP is already fixed
thanks
Dave
I have a 97 12v
thanks
Dave
I would grab a set of 215 inj
Studs( 12mm ARP's) - E bay 417.00 ( i paid for mine )
Applied Performance 801-011 Stage 1 Turbocharger
will support 500 hp
if the timting is set correct, you shouldnt need H2o/meth ..
as far as the clutch .. alway over buy - set your HP goals low and buy high ... then it sould never be the weak link ..
will support 500 hp
jeremy01995
Sep 14, 2015 06:34 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Omingnome
Oct 20, 2014 12:25 PM
