99 cummins cutting out!!
Old Jun 20, 2014 | 01:31 PM
ryank 199's Avatar
Default 99 cummins cutting out!!
I've been having a lot of problems with my 99 trying to figure out what is causing it to cut out. The boy I got it from had the same issue an they replaced the ip an the lp an it fixed it for idk probably about 25,000 miles. Then when I bought it an I drove it for a bout a month an it started cutting out wasn't bad at first then steadily got worse. I could take an swap relays an it would go away for about 30-40 miles an come back I thought maybe lift pump was going bad so I ordered a raptor 100 gph with the 1/2 lines. It seemed to fix the problem for about 2 tanks of fuel an started again. I've check all the plugs to make sure they were getting a good connection. But any suggestions would be great.
Thanks.
Old Jun 21, 2014 | 07:41 AM
lukesdiesel's Avatar
How is your fuel pressure going to the VP44?
Diesel Dawgs Performance
Old Jun 21, 2014 | 08:17 AM
ryank 199's Avatar
We got it set at 15 psi at idle
Old Jun 21, 2014 | 09:13 AM
How does it do when it starts to cut out?
Old Jun 21, 2014 | 12:04 PM
ryank 199's Avatar
It's like a quick jolt. Sometimes it's just once other times it does it multiple times in a row. And it's kinda random never does it at the same rpm or gear different each time
Old Jun 21, 2014 | 12:15 PM
Bigg Redd's Avatar
You mentioned you checked your electrical connections, but ya may have a short in an existing wire(s). Check your wires and make sure there is no short, broken wire inside the insulation, chafing wire(s) touching metal etc.....
Also make sure your ground connections are clean and making good contact.
Just tossing it out there.
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dertyd
24
Jun 7, 2015 02:45 PM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
