Lose the Condenser?
Old Jun 18, 2014 | 08:31 PM
LostSoul71's Avatar
Default Lose the Condenser?
Not sure if I will see any gain as far as cooler air giving me cooler EGT's but I was installing some lights behind my grill and noticed that if I were to pull the A/C Condenser that I could adjust them more and it would also free up the entire IC to cool flowing air. I am running manual, so there is not Oil cooler blocking the Drivers portion of the IC and removal of the condenser would effectively open up the other 3/4's of it to fresh unmolested air. My A/C has never worked and I am not looking to make it do so as it will not be worth the time and money. So my question is do you think the freer flowing potentially cooler flow over the IC would make enough of a difference to make it worth pulling the condenser off?
Old Jun 18, 2014 | 11:35 PM
4x4manonbroke's Avatar
Not gonna notice a big drop .. more EGT dropping with timing Or injectors/turbo ...
Old Jun 18, 2014 | 11:43 PM
LostSoul71's Avatar
I am waiting on the injectors and 60LB springs now. Turbo should be in July. I just wondered if it was worth the effort or not. I figure since I am in there I am going to do the Valve seals at the same time.
Old Jun 19, 2014 | 06:24 PM
The CAC is only so efficeint at pullin heat form the charged air ...
Old Jun 19, 2014 | 08:11 PM
LostSoul71's Avatar
Good point, I will hook up a NO2 bottle to blast over it HAHAHAHA.
Old Jun 19, 2014 | 08:38 PM
JBearSVT's Avatar
I couldn't live without AC.
Old Jun 19, 2014 | 10:50 PM
LostSoul71's Avatar
This area of Canada only has two seasons. Too frigging hot or too frigging cold so I am used to it.
Old Jun 20, 2014 | 12:34 AM
I think the CO2 isnt to bad of an idea .... on the Dyno, that would be awesome ...
