2nd Gen 12valve Ideas
Old Jun 16, 2014 | 02:50 PM
kimberranch's Avatar
Default 2nd Gen 12valve Ideas
Hey guys, i have been saving up for a while and i am getting quite close to having around 20,000 to throw at a 12v setup to put into my 61' chevy pickup to make a ratrod/sleeper out of it. I am wanting to build it up as much as i can now, but i am planning on continuing to add untill i hit the 800-900 horse range. Just need some ideas on what things to do now while i have big money such as tranny, clutch or torque converter, injector pump etc. Im a Duramax guy but way to lazy to fight that battle with a old truck.
Thanks
Old Jun 16, 2014 | 04:24 PM
the.beard's Avatar
If I were going to dump a ton of money into a transmission and didn't want to build it myself, I'd call Suncoast. Spend some jack on the full billet unit and have it installed by a local Suncoast authorized tech and I defy you to break it in a streetable truck. If you break that thing within a year (good luck), they'll replace it for free, even if you use it for competition. While you've got the money, if you want big power, it's a no-brainer that you'll want a 180-215hp p7100 injection pump, lines, case, etc. The 215s make more from the factory, but around here the 180s are preferred for tuning.
Assuming you already have a 6BT to start your build and considering your ultimate goal, that's where I'd put my priorities.
Old Jun 16, 2014 | 05:38 PM
yeah thats what i was thinking, and definately the 215 p7100, my uncle works at moonlight diesel in logan, utah so i have a good hook up for parts and expertise just getting some more opinions, i really appreciate it, any sugguestions on a rear end?
Old Jun 16, 2014 | 07:04 PM
4x4manonbroke's Avatar
In a street truck I would go D80 trimed down with a disc conversion and Crome shafts, also might want a spool in there (LSD might live for a few rounds ) ...
Compunds are the only way to go ..
Old Jun 16, 2014 | 07:05 PM
Old Jun 16, 2014 | 07:22 PM
I'm definitely putting a compound setup on it, and I may also drag race the truck a bit, and maybe hook up to a sled now and again, just mainly a truck I'm planning on driving a little bit around town, but mainly just a high powered weekend warrior type of truck
Old Jun 16, 2014 | 07:35 PM
A D80 will do, maybe do a set of Progressive Coil overs, bags if you intend on hauling anything ...
Old Jun 16, 2014 | 07:48 PM
Okay, thanks for the suggestions
Old Jun 16, 2014 | 10:29 PM
Would like to see what your starting with if you get the chance
Old Jun 16, 2014 | 10:34 PM
Okay, I'm still a little ways out on starting that's why I'm looking for suggestions, but I haven't decided weather to get a used motor and overhaul/ refresh it, or just start from a short block. The short block will cost more to go that way but I will have a nicer setup in the end.
