Bad fuel Replaced everything NO Start
Old Jun 15, 2014 | 09:27 AM
Corys1966's Avatar
Default Bad fuel Replaced everything NO Start
Happy Father's Day
2011 6.7 77k miles with H&S mini max df delete ran perfect before extremely bad fuel ie. water. After truck would not start I Installed airdog 165, 33% over pump, Industrial Injection 60hp injectors, Egr cooler delete, new common rail with plug and new pressure sensor, sinister throttle valve delete, new cam position sensor. Removed the factory fuel canister. The only code is water in fuel. Would this keep from starting? It just spins. Even tried a gas rag. It just bobbled for a second. Im fairly mechanical, but this has me in a bind. Even thinking anti theft, but not sure how to check that. Scanner shows fuel. I know its self priming but i crack a line on the rail to bleed and still nothing. Head gasket? How would I ck that? Any help would be greatly appreciated.
Cory
Old Jun 16, 2014 | 04:55 PM
Rooster24v's Avatar
did you bypass the factory fuel filter? the water in fuel light shouldn't be an issue with it not starting. did you prime the airdog filters?
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
RatsMC
May 4, 2015 05:25 PM
ninetyoned250
Mar 1, 2015 09:10 PM
moneypitk5
Feb 12, 2015 11:01 AM
