no 4x4
Old Jun 14, 2014 | 06:00 AM
6.0's Avatar
6.0
Default no 4x4
4x4 is not working. My heat and air were blowing out the defroster now it blows out the vents Like it it should but my 4x4 doesn't work the elec or the Manuel. No light or nothing. Last time it worked was when I went through the car wash and the wheel cleaner turned on my Manuel hubs about two weeks ago. Tried the 4x4 in field Yesterday and nothing. Had to be pulled out
Old Dec 17, 2014 | 09:56 PM
Rufinator's Avatar
If you turn the key on, and wait for all the clicking to stop, then flick your 4x4 switch, you should hear the actuator on the t-case, if not, it could be the fuse, the switch, or just a bad actuator,
If you hear the actuator it could be the locker in one of the hubs, or something in the t-case.
Old Dec 18, 2014 | 03:12 AM
detroitdiesel idi's Avatar
Check vaccum lines as well
Old Dec 22, 2014 | 07:48 PM
Adrenaline junkie's Avatar
Check the fluid level in your t case also. It uses auto trans fluid and leaks out a little at a time. Most of us don't think to check it but it can cause real problems if too low.
Sep 15, 2015 07:40 AM
Feb 24, 2015 04:00 PM
Dec 7, 2014 11:20 AM
mabr0503
Nov 27, 2014 01:36 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
