48RE Need some help
Old Jun 14, 2014 | 02:26 AM
dave2378's Avatar
Default 48RE Need some help
Alright I'm looking into getting a 2005-2006 5.9 4x4 in the near future. I have been reading forum after forum to get advice and am a bit lost. So thought I would start my own thread.
What I want to do is to boost my hp to around 450. Prob going to go with Edge juice w/ attitude and a few more air flow upgrades. I want to be able to run all 6 stages. I don't want to blow my transmission. I'm not going to tow except on a rare occasion. Not into drag racing, just want the power there if i need it. Might gun it for fun on occasion but just a daily driver.
What trans upgrade should I go with to safely handle the extra hp? I've hear tc and vb upgrades. What else? What about a shift kit? What does that replace compared to an upgrade kit. Which is better and do i even need an upgrade and shift kit?
Thanks
Old Jun 14, 2014 | 10:06 AM
AHolt's Avatar
If you are going to use a programer, you will need to do
some upgrades. min tc and vp, I would also do flex plate.
Old Jun 14, 2014 | 10:39 PM
dangerous1965's Avatar
If you do a TC and VB do the input shaft to!
Old Jun 15, 2014 | 12:02 AM
dave2378's Avatar
Ok so a good tc and vb plus a billet flex and input shaft. Would i be good to go if I don't dive like an ******* haha. What about the internals
Old Jun 15, 2014 | 09:29 AM
lukesdiesel's Avatar
If you get an 06 I would go with EFI Live. As far as transmission goes I would go with a upgraded unit from Firepunk.
Diesel Dawgs Performance
Old Jun 15, 2014 | 03:11 PM
dave2378's Avatar
So would you go with the tow master or street/track trans. The tow only has a single disc tc
Old Jun 15, 2014 | 03:27 PM
Hut's Avatar
Hut
What is great about those firepunk transmissions? How do they compare to Goerend for a towing rig.
Old Jun 15, 2014 | 08:31 PM
dave2378's Avatar
Any other opinions on upgrades.
Old Jun 15, 2014 | 08:41 PM
Depends on your future plans for the truck. The single disc they use is rated to hold 500hp.
Old Jun 27, 2014 | 12:32 AM
CumminsDieselDaddy's Avatar
Hey guys, I have an issue where anytime my throttle is @ 100%, my PCM gives the command to the trans to drop down into 2nd gear. I can assure you everything is mechanically sound. With the scan tool hooked up, you can watch the throttle percentage. If you only press it to 98-99%, it never does it. Once it see's 100%, it down shifts. It just started out of the blue. Would you suggest a ECM/PCM reflash?
