2003 Ford F250 Powerstroke Oil leak after oil cooler replacment
Old Jun 11, 2014 | 06:14 PM
JaredP's Avatar
Default 2003 Ford F250 Powerstroke Oil leak after oil cooler replacment
Hello all, just purchased the F250 a short while ago from a "friend". It was supposed to have the EGR delete and other maintenance done to it. After just having the oil cooler and EGR cooler fail, I've found I have a small basket case!
I just finished putting it together with a EGR delete and new oil cooler. I reused the old oil cooler plate assembly. After starting the truck, I have two issues
1: Exhaust leak at the uppipe to turbo (easy enough)
2: Major oil leak while running. It comes from the EGR cooler jacket area towards the front. Here are two pictures before/after. Assembled with all new ford O-rings and gaskets. Trying to get advice before I tear it back apart.
Other maintenance done-
New water separator manifold
Billet fuel filter cap
Blue spring upgrade
Clean/repaired turbo
Flushed coolant and replaced with ELC and distilled water
Old Jun 11, 2014 | 08:23 PM
bobfbigman's Avatar
you have to remember that the oil resivoir for the HPOP us pressurized to about 75psi so a if that oring/the crazy one under the housing/ is off a little it will create a large leak. make sure all the bolts are tight
Old Jun 11, 2014 | 09:03 PM
JaredP's Avatar
Thanks Bob, the leak is from the multilayered area by the egr cooler. Is it possible it cracked? One bolt broke there and I drilled it out and tapped it for a new bolt. I torqued it to spec. Is there coolant in that area too? I guessi need to take it apart. ={
Old Jun 26, 2014 | 03:57 PM
JaredP's Avatar
Just to follow up, it was a O-ring that pinched on the cooler as it slid into the base plate.
Old Jun 27, 2014 | 10:20 AM
JaredP's Avatar
Just did it's first full test drive last night and its off to work today since the repairs, holy cow it's a different truck than before. It's amazing when everything is right how much it screams! Had someone is a Duramax2500 learn a valuable lesson about the 6.0!
makuloco2000
Dec 20, 2015 11:19 PM
tim12valve
May 6, 2015 10:40 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
