1997 dodge diesel brake issue bad
Old Jun 11, 2014 | 12:58 AM
cummins Pride's Avatar
Default 1997 dodge diesel brake issue bad
My buddy 1997 12v 2500 is having some very serious break issues that left us on the side of the road and got rescued by a 6.0 power-stroke need help bad. About 9,000 miles ago had the front end completely rebuilt by Les scuab for 2k. Passed couple months abs lights been on but never had a issue. But a week ago the pressure line blew to the power staring pump. Just replaced it and put new fluid in. Drove about 15miles and the drivers front side tire starting making some nasty metal grinding noise and started smoking. Seemed like the break pads seized or something and tire started to wobble. What should i do take it to the shop that did the work and make them fix it buddy doesnt have much money.
Old Jun 11, 2014 | 01:59 AM
detroitdiesel idi's Avatar
Sounds like caliper overheated and piston swelled parts should be under warranty
Old Jun 11, 2014 | 04:50 AM
dieseldemon61's Avatar
It's worth a shot, sure it's not the hub?
Old Jun 11, 2014 | 10:19 AM
4x4manonbroke's Avatar
Well, Due to Shwab's ... my F-250 now has a crashed front end ... they left out my brake pawl that go between the brake cyl and the frame of the shoe's ..... had to stop on brakes, and blew out the R rear cyl ...
I would say take it back, but if its a caliper , they would have not known that it was going to happen .. so they might help you , but its gonna cost ya !!!!
Old Jun 11, 2014 | 12:43 PM
i know the rotor was cooking hot so properly warped it (but i have the machine to cut it flat). Think shwab's didn't do something correctly no reason for this to happen
Old Jun 11, 2014 | 12:54 PM
Replace the rotor .... if its warped, just junk it ..... if you turn one, turn them both .. it could cause un balanced braking and possibly pulling under braking...
Dec 10, 2019 10:10 AM
Dye Guardian
Aug 1, 2015 01:28 PM
RedChevy44
Apr 21, 2015 05:47 AM
Nov 6, 2014 08:10 AM
Nov 4, 2014 08:10 AM
