1A Auto Parts Visit - 1A Auto Parts
1999-2007 Ford F350 Truck Power Heated Signal & Clearance Light Telescoping Towing Up
Old Jun 4, 2014 | 10:15 AM
1ATony's Avatar
Default 1999-2007 Ford F350 Truck Power Heated Signal & Clearance Light Telescoping Towing Up
VISIT US HERE FOR GREAT PRICES 1999-2007 Ford F350 Truck Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pair
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!!
These replacement UPGRADE mirrors are just what you need to get your truck in good working form again!
Specifications:
Both LH (Driver Side) & RH (Passenger Side)
Specifically designed as UPGRADE bolt-on replacements for Super Duty trucks*
'08 model style
Includes harness adaptor for use with models with a round plug
4 stud mounting
Has the following options:
Power upper glass operation
Heated
Turn Signal
Dual Manual telescoping arms
Clearance lamp
Includes both Chrome & PTM caps
paint to match caps can be painted to match by buyer or installed as-is
Direct replacement upgrades
Built to strict quality control standards
NOTE: Models with round connectors will only be wired for the power function. Heat, Turn Signal, and Clearance Lamps features will not function.
These mirrors are designed to replace the factory mirrors and will install just as the originals do. They make perfect replacements with great upgrades that have good cost savings over the dealer parts.
Upgraded Mirrors Note:
This set of upgraded mirrors are designed to fit and function just like the original. However, if the vehicle did not come equipped with all of the features noted, additional wiring may be required for complete operation.
2001 Ford Excursion Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pair (Built After 2/18/01 Production Date)
2002-2005 Ford Excursion Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pair
1999 Ford F250 Truck Super Duty Power Heated Signal & Clearance Light Towing Telescoping Upgrade Mirror Pair
2000-2007 Ford F250 Truck Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pair
1999-2003 Ford F450 Truck Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pair
1999-2003 Ford F550 Truck Power Heated Signal & Clearance Light Telescoping Towing Upgrade Mirror Pair
