Returning to Idle Hiccup
Old Jun 3, 2014 | 01:57 PM
Swaparoo's Avatar
Default Returning to Idle Hiccup
Hopefully someone can shed some light. Motor starts and idles fine, revs with no hesitation but when throttle is released and RPM's drop it has a sort of a hiccup for a split second and then returns to idle fine. Any ideas?
Old Jun 3, 2014 | 05:08 PM
4x4manonbroke's Avatar
Sounds normal, I believe that's the sound of the Governor Returning to idle position.... As long as it runs fine I wouldn't let it bother ya too much
Old Jun 4, 2014 | 08:15 PM
LostSoul71's Avatar
Mine will do this when it is cold, but it is not something I see when it is warmer. I know that is not much help but it could be something to keep an eye so don't just fluff it off. Monitor it under several conditions and see if it is consistent.
Old Jun 4, 2014 | 09:22 PM
Could have something worn inside the Governor housing causing it to do that, but usually its just a leveling out when its cold.... Or not up to temp yet
Old Jun 5, 2014 | 07:53 PM
Swaparoo's Avatar
I should have probably said this in the original post. This motor has just been installed in the truck following a complete rebuild. It is so new that it has 0 miles on it. I might also add that I have never run 5k GSK's before either so I am not familiar with their characteristics. I have a video of it with sound but I am not sure how to post it.
Will do some research and try to post.
Old Jun 5, 2014 | 08:40 PM
if its on YouTube.... seperate window on comp. highlight the address bar and right click, select copy and then go to window on this thread in the seperate window and right clich here in the box and select paste ... Then hit Post reply... we will all see it then
JoeyMiR
9
Feb 3, 2018 10:05 PM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
