trans temp light on!?
Old Jun 3, 2014 | 03:39 AM
hectorsalinasx's Avatar
Default trans temp light on!?
Alright guys, Im having this issue with my trans, the trans temp light came up and it wont shift into OD, I came back home parked and took another car to work, next morning I go to turn it on and the light is still ON after seating all the day and night, I know is not hot so that makes me think that that is the trans temp sensor malfunctioning. Truck is a 97 cummins 5.9
I have search here and this thread is the closest i found to it...similiar issue but still took me nowhere
https://www.dieselbombers.com/12-val...mp-sensor.html
Where does the temp sensor goes? I red that on the 97 it goes on the valve body, so i would have to remove the oil pan right? the problem is that i cant find that part anywhere, I need to see what it looks like to be able to identify it once i remove the pan.
Does anybody has a part#?? or is it the pressure solenoid that goes all into 1?
thanks in advance guys, hope you can help me.
Old Jun 3, 2014 | 11:09 PM
4x4manonbroke's Avatar
I thought it was in the return side of the trans line ... ?
Old Jun 4, 2014 | 08:24 PM
LostSoul71's Avatar
Check to make sure all your plugs on the transmission are still connected properly. Sounds like the sensor is done but it could be something as simple as a plug loose or a bad wire to the plug. Cheap fixes first over replacement parts.
Old Jun 4, 2014 | 08:31 PM
I agree as well. ... Do check everything first
casper83
23
Jul 27, 2015 01:53 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
