5th gear. NOT THE NUT!!!!
Old May 25, 2014 | 04:13 PM
96cumwagon's Avatar
Default 5th gear. NOT THE NUT!!!!
Hey guys I'm talking to a guy about a 96 cummins. It's got a 2wd nv4500 with the 205 divorced t-case. He says he welded the nut. But it's making a noise now??! It has some upgrades to it with only 183k on the clock for 5500$
Wanna see how much extra I'm going to spend on fixing this problem
Old May 25, 2014 | 05:40 PM
coors_man_2005's Avatar
The nut prolly broke. I have read about that a few times cause when you weld on something that has been hardend. You just made it weak.
Old May 25, 2014 | 10:56 PM
4x4manonbroke's Avatar
Its because when you weld a nut thats Grade 5 , you temper it and it can becme like a grade 8, or higher ... which means it will be come brittle ( stronger is not always better )
Like when you install manifold bolts, use grade 5 bolts ... when you take them out, there too brittle to re-use ... they will break if you attempt to reuse them .
corksil
Aug 2, 2015 10:19 PM
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
rtbcoop
Nov 29, 2014 11:33 PM
miked2805
Oct 29, 2014 06:20 PM
