Loud front axle noise HELP please
Old May 25, 2014 | 10:19 AM
lancegibbs51's Avatar
Default Loud front axle noise HELP please
My passenger side hub went out on me and I replaced that but it was still makin a loud metal to metal flop noise and vibrated at 45 or faster. Started lookin and replaced all away bar bushins still didn't fix it. So I took the cover off the 4x4 actuator housin and the 2 axles u see in there I can make smack the axle tube walls with my fingers. Wat exactly is broke? I'm pretty confused about the whole deal
Old May 25, 2014 | 03:24 PM
4x4manonbroke's Avatar
U joint is shot ... gonna need to pull the wheel, hub, pull axle and press in a new U-joint , then re-assemble .... make sure you apply some Anti-seize to the inner bore of the hub bearing - helps aid in the removal if needed .. may want to do both sides ..
Ltracer250
6.7 Liter Dodge Cummins 2013+
Feb 27, 2015 10:57 PM
Dak_summers
Jan 22, 2015 08:45 PM
Natenelson1
Jan 19, 2015 07:23 PM
2FordStrokers
Jan 11, 2015 09:40 PM
natenel1
Oct 26, 2014 03:09 AM
