06 Rebuild - Cam question
Old May 24, 2014 | 08:29 AM
vr1967's Avatar
Default 06 Rebuild - Cam question
Been lurking a while but haven't posted but here goes....
Truck is an 06 2500 Megacab 4wd with a 6 spd. Has 138K miles on it - all stock, but has aftermarket 4" turbo back exhaust.
The other day I lost a valve seat, broke a valve. Damaged the others in #5 hole.
Talking to engine builder, he said since truck is stock, he has no problem rebuilding with a stock cam, but does offer Hamilton or Colt Big Stick if I am interested.
I know nothing of either of the aftermarket cams. One better than the other? Lift and duration are close on both.
Again, truck is daily driver, do tow a good bit, usually 10K or less. Only upgrade will probably be a Smarty Jr, but that is it.
Engine will be built with QSB480 pistons, so I know I will have to change injector tips.
Any pros or cons to the aftermarket cams?
Thanks.
Old May 24, 2014 | 06:50 PM
AHolt's Avatar
Those to guys worked together, then went there own ways.
Make sure if you go with colt you are not buying a regrind cam.
Hamilton will be new. colt could be a used regrind. make sure
you know what you are getting.
Old May 25, 2014 | 06:25 AM
vr1967's Avatar
Thank you.
wolfriver
Mar 23, 2016 10:18 PM
Dodge2006/5.9
Jul 20, 2015 01:21 PM
davidthomas
Mar 24, 2015 12:41 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
