tranny noise
Old May 22, 2014 | 10:56 PM
blue ox's Avatar
Default tranny noise
Sooo I was heading down the freeway doing 60mph towing M105A2 trailer I just picked up off craigs list when I start to hear a kinda bearing noise, not sure where its coming from so I pull over and start to check things out, not leaking any fluids that I can see no obviouse drips so I wait until traffic is clear I take off on the shoulder of the freeway get to 2nd gear and noise is still there go to 3rd and it gets a little louder so I called a wrecker got towed home and started looking for the noise I found that my trans was blowing oil out the breather tube I think, there is a rubber hose that comes from what looks like the top of trans and is secured to about a 4" hard line bolted to the back of engine tranny oil blown all over trans and exhaust, pull filler plug cannot touch oil , pop right side pto cover and drain a little more than a quart of oil out 3 quarts short and oil is got glitter in it and fine stuff in the bottom of trans, not sure what to do next just replace nv4500, upgrade to a 6 speed or try to rebuild this myself, what is everyones opinion are these hard to rebuild, thanks for any imput Eddie.
Old May 23, 2014 | 12:19 AM
LostSoul71's Avatar
Did 5th gear come loose on it? I would look into a rebuild kit for it if you are mechanical, I have not done one, but I have done a few Samurai Transfer cases as well as a couple of Toyota units and I cannot see these old NV's being that tough to do. I have really heard mixed ratings on the 6 speeds so I would be apprehensive about installing one in mine. I have driven a 6 speed truck and I was not overly impressed with the Tranny but to each their own I guess.
Old May 23, 2014 | 11:55 AM
blue ox's Avatar
Not 5th gear I had that fixed about 5 yr ago ,I'm going to research on rebuilding it myself
Old May 23, 2014 | 09:16 PM
LostSoul71's Avatar
Can't hurt, if you are in there, look at replacing anything that you can upgrade at the same time. One time rebuild if you can.
Old May 23, 2014 | 10:15 PM
4x4manonbroke's Avatar
Yeah better to catch it early and fix and up grade now .. next time it can get spendy, and really metallic .. LOL .. I learned the hard way with a 14 bolt corperate diff ... 1800 later .. was wishing i had just changed the carrier bearings ... locked up a diff and towed to a shop and such !!!!! it was a real pain in the wallet ...
Old May 24, 2014 | 11:32 AM
blue ox's Avatar
Default rebuild
I've been trying to find some info on rebuilding it but cant seem to locate any videos or info on rebuild kits I dont want to take it apart without first looking at what I'm getting into.
Old May 24, 2014 | 01:07 PM
Good thinking ...
Old Jun 2, 2014 | 11:57 AM
blue ox's Avatar
Update, I found a place in Tennessee called High Gear.com has new OEM nv4500 they bought from new venture when they closed up shop with updated main shaft splined to the end and 5 th gear update 12 month 12000 mile warranty dyno for leaks and operation $1495.00
Old Jun 2, 2014 | 11:58 AM
blue ox's Avatar
O, any ideas on clutch last one was just a stock from local a/p store
Old Jun 2, 2014 | 02:19 PM
South bend ... Go dual disc, and don't look back.... If you never have the big power it will last a real long time then ...
