tranny noise
Old May 22, 2014 | 10:50 PM
blue ox's Avatar
Default tranny noise
Sooo I was heading down the freeway doing 60mph towing M105A2 trailer I just picked up off craigs list when I start to hear a kinda bearing noise, not sure where its coming from so I pull over and start to check things out, not leaking any fluids that I can see no obviouse drips so I wait until traffic is clear I take off on the shoulder of the freeway in 2nd gear and noise is still there go to 3rd and it gets a little louder so I called a wrecker got towed home and started looking for the noise I found that my trans was blowing oil out the breather tube I think, there is a rubber hose that comes from what looks like the top of trans and is secured to about a 4" hard line bolted to the back of engine tranny oil blown all over trans and exhaust, pull filler plug cannot touch oil , pop right side pto cover and drain a little more than a quart of oil out 3 quarts short and oil is got glitter in it and fine stuff in the bottom of trans, not sure what to do next just replace nv4500, upgrade to a 6 speed or try to rebuild this myself, what is everyones opinion, are these hard to rebuild, thanks for any imput Eddie.
Old May 23, 2014 | 12:31 PM
six speed's Avatar
it's not to bad. the fifth gear jam nut is a booger.hopefully you haven't welded it on. i drilled 2 holes in mine then broke it with a chisel.somebody had beat it on with a punch. i wanted to see how it worked since i had never been into one, so i moved the shifter with the input shaft out and successfully launch a spring and dog out the front.so i took it apart and put it back together, never having been into one before.
Old May 23, 2014 | 03:30 PM
4x4manonbroke's Avatar
My understanding is there real simple, of course I do 13,18speeds so , these little ones are a sinch to pull and redo ...
boostkid
Jun 3, 2015 11:17 AM
Boatman
Mar 20, 2015 10:00 AM
Dak_summers
Jan 22, 2015 08:45 PM
2FordStrokers
Jan 11, 2015 09:40 PM
dutchsupreme
Dec 18, 2014 01:44 PM
