What's the best epoxy to use?
Old May 22, 2014 | 09:42 PM
Jordan1233's Avatar
Default What's the best epoxy to use?
I recently installed new fenders on my f250 and I just painted it last month with plasti-dip. I was going to put the f250 badges back on the fenders and I was wondering what the best epoxy or adhesive would work the best?
Old May 22, 2014 | 10:30 PM
4x4manonbroke's Avatar
Get some 5 Ton epoxy .. it wont come off ...
Old May 22, 2014 | 10:48 PM
Remember to use sparingly , dont want it to ooze out from under the Badges.....
Old May 22, 2014 | 11:33 PM
Jordan1233's Avatar
Thanks
Old May 23, 2014 | 10:34 PM
np
Old May 23, 2014 | 11:29 PM
Sycostang67's Avatar
I use a gasket material called "The Right Stuff", it works pretty good, used it to glue mirrors and trim back on without issue.
Old May 31, 2014 | 07:32 PM
That would work on some stuff, if you ever intend on using a pressure washer, your badge will likley get blown off .. I love "The Right Stuff" .. it is the right stuff in most cases..
Old Jun 1, 2014 | 04:10 PM
I have never heard of "5 Ton epoxy", where do you find it?
Old Jun 2, 2014 | 02:14 PM
True Value hard ware does have it, or can get it .... Even 2 Ton will hold for a long time if peeped right ... I would scuff with 40grit only where needed .. It will stick
Old Jun 2, 2014 | 04:28 PM
gunman41mag's Avatar
Moderator
I'm old fashion I like JB Weld
