1A Auto Parts Visit - 1A Auto Parts
1999-2003 Ford F450 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror
Old May 21, 2014 | 12:10 PM
1ATony's Avatar
Default 1999-2003 Ford F450 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror
VISIT US HERE FOR GREAT PRICES 1999-2003 Ford F450 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror
FREE SHIPPING IN THE LOWER 48 STATES ON ALL ORDERS!!
These replacement mirrors are just what you need to get your Ford Super Duty truck in good looking form again!
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side)
Manual operation
Dual Arm
Folding mirrors - Can lay flat against the doors
Telescoping - Slide in and out for adjustment
Direct replacement mirrors
Textured black finish
Built to strict quality control standards
Unheated
For 08-10 models, the appearance will differ from the factory towing mirrors
NOTE: Ford truck mirrors are available with either Single Swing (90 degree rotation) or Double Swing (180 degree rotation) mirrors. These mirrors are interchangeable. Check our other listings for the Single Swing (180 degree rotation) design.
Note: Each of these Super Duty mirrors have (2) mirrors, (1) large and (1) small. On the RH (Passenger Side), only the smaller mirror on the bottom is convex. The larger mirror is not. This is the same configuration that was originally used by Ford.
We have noticed that there are many inferior quality mirrors on the market. We have researched other mirror manufacturers and are only selling what we believe to be the highest quality, best fitting, aftermarket mirrors available. So don't be fooled by cheaper made imitation mirrors. Go with superior quality!
These Ford Super Duty Truck mirrors make great replacements and have good cost savings over Ford mirrors.
SPECIAL NOTE:
This mirror is designed to replace an original mirror with these exact options. If you do not have the options listed, there is a possibility that this mirror may not function properly.
VEHICLE FIT
2000-2005 Ford Excursion Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror Pair
1999 Ford F250 Truck Super Duty Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror Pair
2000-2010 Ford F250 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror Pair
1999-2010 Ford F350 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror Pair
1999-2003 Ford F450 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror Pair
1999-2003 Ford F550 Truck Manual Towing Telescoping 90 Degree Swing Dual Arm Mirror Pair
Oct 14, 2014 08:40 AM
