throttle revs up on its own
Old May 20, 2014 | 09:00 AM
cfarley0210's Avatar
Default throttle revs up on its own
for some reason my sig is not updating my new truck but i have a 07 cummins with a 5.9 and a 6 speed ppe tuner and a few other mods.
but anyways there are no codes present but when i am driving normal there is no issue but when i want to have some fun and start running it hard and grabbing gears i will let out on the throttle between gears and push the clutch and the engine will continue to rev up past redline up to about 3500 rpm. one of my friends has a similar truck and his did the same sort of a thing is this normal or is there a issue? if its normal is there a way to stop it from happening?
Old May 20, 2014 | 10:49 AM
cerberus60's Avatar
The CR's are not going to back off like a jerk when you liftt off the throttle and when you unload the engine bu cluthcing it the rpms will jump. That said some tuners and certain tunes will make this worse.
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
Jake202
Jun 21, 2015 09:42 PM
rusty 6.5
Jun 13, 2015 05:45 PM
1stgenswap
Nov 3, 2014 09:45 PM
