One blinker doesn't work
Old May 18, 2014 | 10:47 PM
Rockstarman's Avatar
Default One blinker doesn't work
Hey guys i got a problem with my 97 3500 5.9 cummins with the nv4500 backed up to it. The driver side front blinker is not working, i have changed the bulb and the relay to no avail. I tried tracing the wires but never found a break or worn spot. I searched the web and the forum but havent found anything matching my problem. Any help is greatly appreciated!
Old May 19, 2014 | 02:46 PM
4x4manonbroke's Avatar
Pull the bulb and make sure your getting power to the center post, as the out side is ground .... If no power, post again...
Old May 20, 2014 | 06:44 AM
There isn't a center post that i know of only two on the left and two on the right
Old May 20, 2014 | 02:36 PM
Ahh, 3156 bulb ??
2 should have power, one for marker the other would be blinker powered
Old May 20, 2014 | 05:23 PM
Yes and i have traced that wire and found 0 breaks or wear marks so thats where I'm drawing a blank.
Old May 20, 2014 | 09:36 PM
ok , Your gonna need to check the blinker multi-function switch , I think your gonna find there is a singnal in but not out....( basically make sure its putting a signal to the blinker relay, might try a known good blinker relay...)
Old Jun 1, 2014 | 11:09 PM
What ahould be the best method to test this?
Old Jun 1, 2014 | 11:27 PM
you will need to back plug check = take a test light, turn on ignition, and test each wire on the truck side ( not the switch side of wiring plug) , and see if your getting the signal there, if not, you have your problem solved ( most likley it would be a bad contact, buy a new switch ) .. if not then test @ blinker realy on left side of dash in the fuse panel... and such forth until you reach your plug @ blinker buld ... somewhere along the line you gonna reacjh a point where there is not a signal ... so from that point to the last point you had a signal is going to be the trouble section of wiring ...
I know, sounds real simple ... been there ( I own a Ford ) ..LOL
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
cjgregory
Mar 31, 2015 01:45 PM
Big Bill
Feb 15, 2015 09:28 AM
bonestock
Feb 1, 2015 08:41 PM
Oct 18, 2014 10:10 AM
