injector swap help
Old May 17, 2014 | 03:19 PM
cummins Pride's Avatar
Default injector swap help
I have a 1996 12v currently with 370 marines injectors.I have been researching and see the bad side effects marines can cause i am wanting to buy 80hp dragon flow injectors. Can anyone help me with how good the quality and benefits i would get with the dragons, instead of the marine 370s.
Old May 17, 2014 | 03:27 PM
just found a good deal of industrial injection 80hp for 498$ complete set
Old May 17, 2014 | 11:50 PM
4x4manonbroke's Avatar
370's are fine , just need to make sure the injector depth is set correctly other wise tey will be smokey as all get out and Hot as well, they need to be set deeper to belnd in the bowl correctly , dont just slap them in .. bad idea
Old May 18, 2014 | 07:15 AM
turbo2332's Avatar
performance wise you will see no difference between the 2 unless your current set is worn. the correct spray pattern injector will however burn much cleaner. pulling trailers, taking off at stop signs ect will be much cleaner.
Old May 18, 2014 | 07:22 AM
turbo2332's Avatar
performance wise you will see no difference between the 2 unless your current set is worn. the correct spray pattern injector will however burn much cleaner. pulling trailers, taking off at stop signs ect will be much cleaner. a 370 injector is roughly a 90hp
Old May 18, 2014 | 01:09 PM
just had the injectors rebuilt and slapped them in. Which im having problems with the truck its a pain to climb hill i have to ho 45mph or my egts are over 1000
Old May 18, 2014 | 03:25 PM
Sam e truck thats making oil in the coolant ?? if so you could have a HG issue and its drinking coolant in to 1 or more cylinders causing low power ( and or compression loss)
Old May 18, 2014 | 08:57 PM
yes, same engine i spent all day taking the engine out of the truck haven't tore the head off yet tho.
Old May 19, 2014 | 02:53 PM
Ok, well keep us posted
Old May 19, 2014 | 05:34 PM
will do
