Bad cough in my cummins
Old May 16, 2014 | 02:06 PM
missmytruck's Avatar
Default Bad cough in my cummins
I just bought a 95 12v and it coughs white smoke when I start it. And it will cough when I give it throttle and then clears up after a minute. But After 2000rpm it won't clear up. And it idles at 500rpm. The truck is bone stock and has 211*** miles. It is a 5spd and has previously been a service truck. It sat since 2/2013. I need some ideas before I get into it.
Old May 16, 2014 | 07:04 PM
LostSoul71's Avatar
You may want to have the injectors checked.
Old May 16, 2014 | 08:41 PM
4x4manonbroke's Avatar
pull fuel filter and fill with ATF, then run the truck up and down the road, it sounds like your fuel has alge in it , when you pull your fuelk filter dump contents into a clean clear jar, if its not clear , you have junk in tank... pull filter and go from there... start simple, then work your way up
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
flatbed_cowboy
9
Feb 26, 2015 04:30 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
