500hp DD
Old May 13, 2014 | 11:14 PM
bajahigh's Avatar
Default 500hp DD
2004 f250 10/03 built date....ok so im shooting for 500hp i got egr delete oem gaskets arp head studs updated oil cooler updated dummy plugs sct with mpt bazooka tune afe cold air intake 4in straight piped s&b intake elbow coolant filter
i figured im about at 450hp right now with my current set up and cant really afford injectors or turbo for awhile plus everyone i know that went with bigger injectors has slipped there trans very badly till it finally left em stranded
so my next question is what can i add to get close as possible to 500hp ficm tune or 58v ficm?? which is better or both?? boost builder?? does the blue spring help that much??
Old May 14, 2014 | 05:02 PM
HeavyAssault's Avatar
Tuning could get you there but it's a hard climb. Plenty of history shows you can't get to 500 without spending a lot more money.
Old May 14, 2014 | 09:49 PM
bajahigh's Avatar
i wanna go with the looney or looney wild can i run those on stock injectors?? i just dnt have money for injectors right now and then im adding blue spring a 58v or tuned ficm and boost builder
whats better a tuned ficm or 58v?? or somethiung like a tuned heavy dity 48v
Old May 16, 2014 | 05:40 AM
SCT tuning will work great on stock injectors. I'd suggest the PHP FICM tuner for FICM tuning. Maybe consider getting the FICM beefed up thru a rebuild before spending for a 58v. The boost builder doesn't do sqat.
Old May 18, 2014 | 08:05 PM
bajahigh's Avatar
with my tunning cold air intake 4in exhaust intake elbow and bullet proofed what do you think im at??
Old May 19, 2014 | 12:41 AM
lpsl12's Avatar
I'm not real certain about the 58V FICM. Thing is, the FICM seems to be under load producing 48V, let alone 58V. PHP FICM tuning might help you out on that one.
Old May 30, 2014 | 01:27 PM
bashby80's Avatar
I have the Looney tune, and I love it. The drivability is dramatically increased, and the power is awesome. She doesn't recommend the Looney Wild w/o head studs installed. The only downfall I've found with it is that my EGTs are much higher than I'd like (my pyro might be too far in also).
I recommend a fuel pressure gauge before going with the Blue Spring, because I did it backwards and found the spring put me at 90. When I swapped back to my stock spring, I was sitting happy at 70. I'm 4" straight piped to dual 5" stacks, coolant filter, stock everything else.
Good luck with your build
Old Jun 1, 2014 | 10:13 PM
bajahigh's Avatar
well i got my boost builder and my spool up time is amazing jumps from 10psi to 20psi then to 37psi and stays there its great next is prob a beefed up 48v ficm with the 80hp or 100hp tune what do you guys recomend?? and how much is the php tuner?? id like to be able to change it when ever i want and im placing my order tomorrow for the looney tune
Old Jun 1, 2014 | 10:15 PM
bajahigh's Avatar
what are some boost number you guys are seeing?? i have a wicked wheel with boost builder and am seeing 37 psi
Old Jun 1, 2014 | 10:40 PM
gunman41mag's Avatar
Moderator
Try METH INJECTION
Water-Methanol Injection: How Much is Too Much? - Diesel Power Magazine
windish62
Dec 9, 2014 08:08 PM
