Another Question For The Airdog Guys
Old Apr 28, 2008 | 08:46 PM
Razutak's Avatar
Default Another Question For The Airdog Guys
I was wondering if any of you guys running the airdog 150 have seen fuel pressures over 30psi?
Old Apr 28, 2008 | 08:50 PM
DangerousDuramax's Avatar
No, and if you do you need to contact Charlie. That means there are not enough shims against the pop-off spring. When are you seeing this pressure? Idle or WOT? At WOT your ok but if you're seeing that at idle its going to cause some issues.
Old Apr 28, 2008 | 11:22 PM
Razutak's Avatar
im seeing this no matter what i do right now
Old Apr 29, 2008 | 02:32 AM
DB Admin's Avatar
Banned
Did you remove the fitting that came installed in the pump factory?
Old Apr 29, 2008 | 08:11 AM
Yeah, that could be it right there. If you didnt remove the fitting its raising your pressure because it's a restriction.
Old Apr 30, 2008 | 04:06 PM
Razutak's Avatar
which fitting is that
which fitting is it that i needed to remove? Thanks
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
98cummins
17
Feb 26, 2015 08:42 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
Oct 27, 2014 09:02 PM
