06 cummins 5.9 fuel pressure
Old May 11, 2014 | 03:05 PM
Stanley123's Avatar
Default 06 cummins 5.9 fuel pressure
Fuel pressure at idl is 3400 wot is 6500 won't start
Unless u use starting fluid will run but not good
Has new injectors code is p0148 what could the prob
Be ?
Fule pressure sensor
Fca - fuel controlled actuator
Was replaced too
Old May 11, 2014 | 04:06 PM
Stanley123's Avatar
Any one have an idea what it is ?
Old May 12, 2014 | 09:01 AM
dangerous1965's Avatar
Unplug the FCA and see what pressure you get. Tighten your crossover tubes be sure you installed properly!
Old May 16, 2014 | 10:58 PM
cerberus60's Avatar
AS a guess, your injectors are not up to par or the install was pooched.
What exactly did you get for an injector? What cross over tubes?
P0148 is low fule pressure, have you checked to make sure the LP is working good?
Old May 18, 2014 | 04:58 PM
AHolt's Avatar
Start at LP, and go from there.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
