CP3 And The FCA........
Old Apr 28, 2008 | 04:52 PM
SuperTrucker's Avatar
Default CP3 And The FCA........
I have been on the phone nearly 3 hours today trying to find the metering valves or even the entire FCA for the CP3. The FCA would run about $165.00 and the guy at Diesel Fuel Injection of Harrisonburg told me that it would be on back order if I ordered it. I want to know if any of you know where to find the metering valves or an aftermarket FCA or even a stock one for cheap...... I did the DIY mod to the FCA and now the entire truck seems like it surges and every once in a while the spring gets stuck and gives me no fuel over stock or less and it is definitely noticeable. I want to fix it and would like to get a couple metering valves to see if I can redo the mod and get it right. Thanks in advance for any input.
Old Apr 28, 2008 | 08:34 PM
wildbill's Avatar
$165??!!!! Cummins sells em for around $100.Give em a call, if you have a local shop.
Old Apr 28, 2008 | 08:43 PM
DangerousDuramax's Avatar
The metering valve is located inside the FCA which is where the wiring harness plugs into. Check out this link: https://www.dieselbombers.com/durama...-yourself.html
Old Apr 29, 2008 | 08:50 AM
staarma's Avatar
Maybe try John at Floor It Diesel Performance (785)842-8545
Old May 1, 2008 | 07:10 AM
I already did the mod. I need to fix the screw up that happened. I need either the FCA or the metering valve. The FCA straight from Bosch is $163.48 and it would be on back order for who knows how long.
