Bad vp44 ??
Old May 9, 2014 | 05:38 AM
dman01cummins's Avatar
Default Bad vp44 ??
Hey guys so this all started with a slight loss of power in first gear, no matter how far I pushed the peddle it would take off slow then would take off and as long as I kept in to it it would hold power. Now about 2 weeks later I have now power at all till about 3rd in the top end of the gear. But if I let the rpms go too low I have now power. Long story short my truck has no power at all unless I can get high rpms. Took the truck to my trusted mechanic and he thinks it's the vp going bad but he needs to test it. Just trying to get some input and see if anyone knows for sure. It throws a map sensor code so I on know what that's about. The vp and lift pump are about a year old the lift lump is new and replaced but still like the stock one. I do have a low fuel pressure light that I know works and I haven't had it go off at idle or wot. Any help would be great thanks
Old May 15, 2014 | 12:10 AM
H.R.D's Avatar
I would say transmission problems.
Sent from my Nexus 10 using Tapatalk
Old May 15, 2014 | 01:28 PM
PeteBug's Avatar
I have 1999 24 valve 2nd generation and with my experience when lift pump dies shortly after the vp44 will die and truck don't start at all. Have replaced 2 vp 44's then I installed a low pressure light. Have since replaced 3 lift pumps about a year apart on those. So yes I would go with trany problems rather than a vp44
Old May 18, 2014 | 10:13 AM
trigger_3001's Avatar
Turbo check out ok?
Old May 26, 2014 | 10:09 PM
allen66's Avatar
Sounds turbo related to me.
Old May 30, 2014 | 07:59 PM
Flikkie2001's Avatar
Ya id agree with the turbo my 02 had similar issue and turned out to be the turbo
justinsbeck
Jan 18, 2016 12:15 AM
|WYG|SS
Jul 4, 2015 08:31 AM
DeLuzGN
Mar 17, 2015 08:08 AM
somarillw
Dec 15, 2014 12:00 AM
12vbomber
Nov 11, 2014 10:58 AM
