Truck won't start cruise control acting up before that
Old May 6, 2014 | 12:48 AM
Dunright mobile's Avatar
Default Truck won't start cruise control acting up before that
Hey guys , I was driving my truck today on the high way and I set my cruise to 100 km (65 miles) and it started to cut in and out. It was very violent. So I shut down the cruise and used my foot. I got to my deistination shortly after that and when I parked I noticed it ideling funny. It seemed like it wanted to idle up and then come down. I wasn't to worried about it till I tryed to start it again and it didn't fire! No codes either. I craked the injector lines and rolled it over , no luck. I did notice my fuel bowl drain valve is leaking slowly , the little screws in there are stripped, could that be it ? I did my vp last winter . Any ideas ??
Old May 6, 2014 | 12:50 AM
And I've got 16 psi at injector pump
Old May 7, 2014 | 09:32 AM
Bump
Old May 11, 2014 | 12:22 PM
Bump again
Old May 12, 2014 | 06:52 PM
james0048's Avatar
Does it still crank? and if it does have you checked the fuel lines to ensure you're getting fuel to the cylinders?
Old May 13, 2014 | 10:56 PM
It was air in the fuel canister I beleave. It was leaking from the drain valve. I deleted it. My fass does all the filttering now
burndiesel
10
Feb 7, 2023 01:15 AM
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
ronstop
Feb 26, 2015 09:48 AM
