coolant any idea
Old May 5, 2014 | 07:29 AM
yfzrunner's Avatar
Default coolant any idea
Ok guys any one have a clue what could of happened. like 3 months ago i changed my coolant hoses waterpump and thermostat. I dont drive my truck much but mainly out of town and on weekends. But the other day after sitting in traffic i pull in driveway and turn truck off and i smell coolant so i open the hood and noticed coolant overflow was almost full and no coolant in top hose . So worst case i was thinking headgasket as the coolant was kind of foamy but i did do fleetguard restore flush. And like 5 days later i go back coolant is back to normal with no oil in coolant are coolant in oil. So i drive the **** out of it and and i mean **** and no problems at all never did overheat ever even when i noticed it the first time. I just thinking maybe sticking thermostat or air in the system not sure any input guys thanks. And last i noticed radiator cap was a **** hair not twisted on all way if that matters.
Old May 5, 2014 | 09:03 PM
twinturbo12v's Avatar
hey, if it stopped doing it and it's not leaking anywhere, dont worry about it. it may have just got hot or something, and a freak occurrence happened. if it isn't giving you problems anymore, i wouldnt worry about it.
Old May 8, 2014 | 03:58 PM
LostSoul71's Avatar
Sounds like you had air in the system and it found its way out. Just keep an eye on it and if it happens again try to determine the events that lead up to it.
Old May 12, 2014 | 10:38 AM
yfzrunner's Avatar
ok thanks guys yes what a piece of mind i was about to pull the head .
Old May 12, 2014 | 02:52 PM
4x4manonbroke's Avatar
Most likely you had an air bubble in the back of the cylinder head , it finally moved enough coolant to allow it to escape into the radiator and out, usually it will push coolant also , do keep an eye on it....
Old May 19, 2014 | 06:11 AM
yfzrunner's Avatar
well ya still no problems but truck seem to black smoke a little more .
Old May 19, 2014 | 02:45 PM
Kewl !!!!
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
Rayrock4
Aug 30, 2015 09:45 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
