Low Oil Pressure
Old May 4, 2014 | 12:22 PM
Justin Kornkven's Avatar
Default Low Oil Pressure
My oil gauge on my 2006 F350 6.0 drops at idle ive replaced the oil cooler along with the high pressure oil rails and pump also my ICP sensor it doesn't throw the engine light at all but it runs fine other then that
Old May 4, 2014 | 01:04 PM
bobfbigman's Avatar
make sure you have the right oil filter, it should be a Motorcraft or a Fram, they are the same thing. some oil filters are too short, aspecially the ones with their own caps.
Old May 5, 2014 | 12:08 PM
That's all I use is Motor Craft on it
Old May 6, 2014 | 12:36 AM
FRIDAY88's Avatar
Have you changed IPR valve? I've had the low pressure G-rotor pump take a poop on mine before and cause this also
Old May 6, 2014 | 01:07 AM
ill have to look into it thanks
Old May 7, 2014 | 08:03 PM
prison's Avatar
Just had that same problem. Leak in hpo line and check ball out on hpop. New hpop and line and it runs great. Is it hard to start after it sits?
Sent from my iPhone using Tapatalk 2
Old May 7, 2014 | 08:37 PM
FRIDAY88's Avatar
06 don't have check ball on pump
Old May 7, 2014 | 08:38 PM
FRIDAY88's Avatar
03 04 have check ball 05 and up don't have check ball
Old May 8, 2014 | 05:51 AM
prison's Avatar
Did not know that. Well the hpo leak still applies but mine gave a code for low icp on cranking
Old May 8, 2014 | 08:49 AM
FRIDAY88's Avatar
I do believe he changed icp and pump and rails but yeah there is a possibility of a high pressure leak for sure
