please help!! speedo issues!!
Old Apr 30, 2014 | 10:18 AM
dodgeramit10's Avatar
Default please help!! speedo issues!!
All at once my truck shifted out of o/d and no speedometer.... plus i lost cruse a few monts ago and my a/c quit working the day my speedo quit.... i dont understand!! I replaced the speed sensor still nothing... checked fuses and all my tps stuff... i dont know what to do and i have a trip this weekend!!
Old May 2, 2014 | 04:34 PM
1stgenctd's Avatar
My problem was the VSS (Vehicle Speed Sensor). Lost O/D and speedo.. Cruise hasn't worked in a long time.. and neither has my A/C, I'm guessing your A/C issue is not related to your speedo and O/D issue.
Old May 2, 2014 | 08:41 PM
My a/c works now... and i replaced the speed sensor and checked the gear that turns it... still nothing... i grounded my overdrive solenoid so i can drive it till i fix the real problem...
Sent from my LGL86C using Tapatalk
Old May 2, 2014 | 08:42 PM
Anything else that i could do to trace the problem down?
Old May 3, 2014 | 09:20 AM
the.beard's Avatar
In my experience, if the VSS isn't the culprit, it's the PCM. This is so common it's unreal.
Old May 3, 2014 | 10:20 AM
The computer?
Old May 3, 2014 | 03:44 PM
the.beard's Avatar
Yeah, PCM=powertrain control module=computer. It controls very little; the speedometer/overdrive, the air conditioning, voltage regulation from the alternator, and grid and fuel filter heaters.
Decomputerizing it is an option. I'm elbow-deep in a Cummins Ramcharger swap and I'm deleting the PCM.
Old May 3, 2014 | 06:50 PM
But everything else works... even the grid heater... is it common for just one thing to go out?
Old May 3, 2014 | 07:48 PM
the.beard's Avatar
Yep. The PCM in my 91.5 refuses to have anything to do with the speedometer but everything else works. Right this moment a GPS is my speedo and o/d is on a switch.
Old May 3, 2014 | 11:49 PM
Will a gas burner pcm work on my truck?
dwmeehan
Jan 29, 2025 12:13 PM
Apr 11, 2015 02:47 PM
Cutlass26
Mar 22, 2015 05:46 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
