IS IT A STARTER PROBLEM OR SHORT
Old Apr 29, 2014 | 05:32 PM
eddiefish's Avatar
Default IS IT A STARTER PROBLEM OR SHORT
On my 2000 dodge 5.9 is having an issue. It is intermittently blowing the ignition fuse when I try and start it. If I jumper across the little purple wire by the battery once it will click the solenoid in and out on the 2nd or 3rd time it will start. Last night I went through 4 fuses before I did the jumper wire. This morning no issue it started like it was suppose to. It could go like this for 1 start or 100 starts any ideas?
Old Apr 29, 2014 | 07:54 PM
coors_man_2005's Avatar
My half ton conversion was doing this. I got tired of dealing with it couldn't find any issues. I know its not very smart. I just put a wire in the fuse slot. Figured if there's an issue I will find it now. Its been like this for around a month with no issues. So I'm interested in this as well.
Old Apr 29, 2014 | 09:17 PM
eddiefish's Avatar
I put in a 30 amp fuse instead of the 20amp will see. I should have the starter checked to see how much it is drawing. Maybe the next time I have a day off and the auto store is open.
Old Apr 29, 2014 | 09:57 PM
I still popped a. 30a
Old Apr 30, 2014 | 05:03 AM
lilmike1540's Avatar
I would check your grounds it sounds like a grounding issue if its really intermittent and you know the relay is good and the fuse is good if the starter were to I fact be bad there are rebuild kits for the contacts in the selnoid motor itself for 35$ but usually when those go bad they are stuck 100% open/off or 100% closed/on hope this helps you guys
burndiesel
10
Feb 7, 2023 01:15 AM
leocanuck
6.0L Performance
Sep 27, 2015 06:05 PM
klein444
Jun 20, 2015 11:48 PM
james2562
Feb 5, 2015 09:05 PM
nevadagramm
Oct 17, 2014 07:59 PM
