03 grid heater/glow plug bypass
Old Apr 28, 2014 | 05:47 PM
oznation's Avatar
Default 03 grid heater/glow plug bypass
Is there a way to bypass these with a lead from the batteries for a start?
Old Apr 28, 2014 | 06:07 PM
mysterync's Avatar
Well yes but why?
Sent from my SCH-I605 using Tapatalk 2
Old Apr 28, 2014 | 06:13 PM
oznation's Avatar
Just in case they ever go out on a cold day. I'm usually out in the middle of nowhere for work.
Old Apr 28, 2014 | 07:00 PM
mysterync's Avatar
You have a grid heater, it's quite unlikely to experience a failure of that system with correct battery maintenance.
Old Apr 29, 2014 | 08:54 AM
dangerous1965's Avatar
Just disconnect the power from the soleniod. I've had an occassional CEL but if you start it right away usually doesn't come on! Never gets cold in CA so I removed the whole assy ran a heater delete. I've been down to 30 and starts right up!
Old Apr 29, 2014 | 08:56 AM
mysterync's Avatar
If your trying to start without grids it's easiest to just remove the slide on signal wire off the solenoid.
Old Apr 29, 2014 | 04:36 PM
Bigg Redd's Avatar
There really isnt any gain by removing the GH. You might gain .5 psi, but at high revs. Its there for a purpose.
Old Apr 29, 2014 | 04:38 PM
mysterync's Avatar
Guess you didn't read the thread
Old Apr 29, 2014 | 04:40 PM
Bigg Redd's Avatar
Whoops! My bad...........its been a long day.
Old Apr 29, 2014 | 05:14 PM
mysterync's Avatar
I'm guilty of it more times than you could imagine. I'd say 80% of my post are completely irrelevant
