Fuel Catalyst
Old Apr 27, 2008 | 04:19 PM
bigbrowngoat's Avatar
Default Fuel Catalyst
can anybody tell me about the fitch fuel catalyst firsthand in the ad. it's said to impove milage by 1-2.5 mpg & help with hp & torque. anyone know if it's the real deal or junk .
heres the ad.
Kit includes
• Installation bracket, cable ties, and the fuel line disconnect tool
• EFI multi port fuel injection hose with Male/Female rail quick connect fittings
The Fitch Fuel Catalyst is a metal alloy that causes a reaction with hydrocarbon fuels such as gas, all diesel fuel, oil, kerosene, etc. This reaction is very similar to the refining process but at a refinery they use heat and pressure to "crack" octane or refine the fuel where we use our metal alloy catalyst to create a similar environment but we do it on board a machine at a low temperature. As fuel passes over the catalyst, it transforms gasoline or diesel into a superior quality of fuel allowing a combustion engine to extract the maximum amount of energy with minimal emissions. The FFC does not lose its potency and never dissolves or deteriorates which is why it differs from additives that require replenishing.
The Fitch Permanent Fuel Treatment transforms gasoline and diesel into a superior quality of fuel, allowing an engine to achieve maximum performance for a warranted period of 250,000 miles. As engine operates most efficiently and produces maximum horsepower and torque when it is running on the highest quality fuel. Gasoline and diesel is at its most optimal quality when it is first refined but unfortunately during storage and transportation, the fuel quality drastically diminishes. Sacrificed horsepower/torque and efficiency of an engine may be the result of this poorer fuel quality. A less than optimal fuel will also produce more emissions, soot build up, and deposits in engine oil and injectors. The Fitch Permanent Fuel Treatment will boost octane in gasoline, increase cetane in diesel and re-refine the fuel quality, returning it to a superior “refinery” fresh state guaranteeing maximum performance and efficiency from the engine. Remember, Fitch is NOT an additive – it is long term fuel treatment offering a number of benefits:
· Increased Fuel Economy (averages 1 – 2.5 mpg)
· Improved Horsepower & Torque
· Improved Cetane & Lubricity in Diesel Fuel
· Reduced Emissions & Soot Build Up
· Extended Engine Longevity
· Reduced Overall Engine Maintenance
cost is $297.99 puls shiping
Last edited by bigbrowngoat; Apr 27, 2008 at 04:19 PM. Reason: Automerged Doublepost
Old Apr 27, 2008 | 05:11 PM
Jazz's Avatar
I did a little research and found this. Hope this helps you a little does the fitch fuel catalyst work ?
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
