Motor or Tranny vibrations
Old Apr 22, 2014 | 12:22 AM
Dirtydanny's Avatar
Default Motor or Tranny vibrations
I have a 2007 F250 6.0L with 61,000 miles. Picked the truck up around three weeks ago from an older gentleman that owned it since new. It's had Mobil 1 Delvac 15W-40 ran through it all its life. About a week ago I changed the oil and put the same stuff in it with the Lucas additive for Powerstrokes. I also had to replace the oil filter cap because it broke while I was trying to put it back on. The truck also came with a Bully Dog Triple Dog Power Pup in the box and was only used on the lowest setting. I have messed around with it a little but ended up putting it back on stock setting.
Before the oil change I had a slight vibration I noticed in lower speeds. I could see my center console shaking and if I had a drink or something in the cup holder I could see or hear it moving. Once I got up in higher speeds and less RPM's it smoothed out.
After the oil change and messing around with the Bully Dog a little I noticed the vibration got a little worse. After cold starting the truck I would rev the motor while in park and I would get noticeable vibration. While driving I am getting vibration especially in a higher gear and low RPM's. If I would stomp on the pedal it would shake real bad until it down shifted and gained RPM's.
Threads I have read:
https://www.dieselbombers.com/ford-p...ibrations.html
I will do the FICM test. My batteries are fine I believe. Fairly new Motorcraft batteries and I put the Lucas additive in it during the oil change so would I still need to put the rev-x additive in as well?
Thanks!
Old Apr 23, 2014 | 01:07 AM
Dirtydanny's Avatar
Possibly FICM? Maybe improper oil filter or filter cap? The filter was a FRAM and the oil filter cap after replacing it because it broke came from a local automotive store.
Old Apr 23, 2014 | 01:21 AM
gunman41mag's Avatar
Moderator
i use FRAM oil filters all the time & haven't had that problem on my 2008 6.4
Old Apr 23, 2014 | 08:38 PM
Adrenaline junkie's Avatar
I would not use Lucas in a ford diesel. The injectors are oil fired and the tolerances are incredibly tight. Rev x seems to help a little but anything thick will probably cause stiction issues. I use 5-40 Rotella synthetic all year long and I don't need to plug in down to 2 deg. In winter. I have over212,000 miles and stock injectors. Your vibration may be misfiring injector. I would try fresh oil and rev x if you feel u need additive.
Old Apr 23, 2014 | 11:21 PM
Dirtydanny's Avatar
I changed out my oil filter and cap again to Motorcraft and I am still having the vibrations. So I have ruled out the FRAM filter and aftermarket filter cap.
Old Apr 23, 2014 | 11:41 PM
Dirtydanny's Avatar
So start fresh and change the oil out again and put Rev-x in it. My buddy changed his oil on his king ranch and used Lucas. He hasn't experienced any of the issues I'm having.
Old Apr 24, 2014 | 04:20 AM
Dirtydanny's Avatar
I am going to have a diagnostics check done on it. It's not throwing any DTC's.
Old Apr 24, 2014 | 05:41 AM
I would definitely check for codes. If you can, get graphs of injectors firing. You should see consistent patterns on all 8 injectors. If pattern is erratic or some are consistent and one or more looks different you have an injector issue that will be magnified with thick additives like Lucas.
Old Apr 24, 2014 | 06:31 AM
Dirtydanny's Avatar
When I take it in for a diagnostics I will have them do check the injectors on a graph, volts for the FICM and a load test on the batteries. Anything else I'm missing?
Old Apr 27, 2014 | 11:49 PM
Dirtydanny's Avatar
I took it to have a diagnostics check and they said I have two injectors bad and my fuel pressure regulator is bad.
Do you think my oil change caused this?
