Followed forum advice, now stuck. Rough running 1500-2000 rpm
Old Apr 20, 2014 | 06:03 PM
doghouserez's Avatar
Default Followed forum advice, now stuck. Rough running 1500-2000 rpm
2004 f350 6.0 210,000 miles. ficm has 7 contact points. Changed fuel filters, oil/filter. Check ficm 48.+V both key on and running. Tried Lucas injector cleaner. Problem is not always an issue. seems bad 2/3+ of the time. Started this winter after I replaced the ball joints, and front bearings, weird. Full tank of fuel. Have not pulled codes yet. Periodically trouble starting. Batteries test at 12+v not running 13+v running. Could it be the fuel pump in the separator? When I did the fuel filters, the upper filter was black. Time to try the HotShot oil treatment?
Old Apr 20, 2014 | 08:51 PM
Adrenaline junkie's Avatar
I would check fuel pressure at the upper filter housing. I always run power service or fppf fuel treatment, seems to help cetane rating.
Old Apr 20, 2014 | 08:55 PM
I havent found out much about ICP and IPR yet(What exactly they are). I will keep trying to find out about them on forum. But, any help would be great. Thanks.
Power service, I have been using the cetane booster and recently the cleaner+cetane. No change. Also, I have cleaned the EGR valve.
Last edited by doghouserez; Apr 20, 2014 at 08:57 PM. Reason: Automerged Doublepost
Old Apr 21, 2014 | 09:42 PM
I'm wondering if you have a bad connection somewhere, harness chafed somewhere? Hot shot will help with injector stiction, where spool valve doesn't work properly to allow fuel into cylinder. If you have bad connector at ICP your ficm won't see oil pressure required to fire. Are there any mods to engine?
Sry, IPR shorted will cause no start, I get em mixed up sometimes
Last edited by Adrenaline junkie; Apr 21, 2014 at 09:42 PM. Reason: Automerged Doublepost
Old Apr 22, 2014 | 06:15 PM
No mods that I am aware of.
Old Apr 23, 2014 | 07:52 PM
Bigg Redd's Avatar
Sounds like the HPOP crapping out. Been there done that, when I owned my 04 Ford PSD.
ssmith.77
Nov 25, 2018 06:56 AM
BYRQN33
Mar 18, 2015 04:12 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
ssmith.77
Jan 11, 2015 02:03 PM
