Air in coolant and over heating
Old Apr 18, 2014 | 11:16 PM
Dpynn's Avatar
Default Air in coolant and over heating
I have a 2008 6.7 cummins I had the head gasket fixed and put arp studs in about 2 years ago but now I'm getting air in my coolant and my temp runs a little high and overheat and loose my heat for a few min any suggestions on what's wrong
Old Apr 19, 2014 | 05:10 AM
lukesdiesel's Avatar
Check the thermostat
Sent from my DROID RAZR using Tapatalk
Old Apr 19, 2014 | 12:36 PM
Dpynn's Avatar
I didn't think if it was the thermostat would put air in the system when I shut it off you can see air bubbles in the overflow
Old Apr 19, 2014 | 06:12 PM
coors_man_2005's Avatar
Its your h/g again.
Old Apr 19, 2014 | 07:37 PM
Bigg Redd's Avatar
Yep, sounds like a head gasket repair. Just for giggles, try re-torquing your head studs. That may buy you alittle time.
Old Apr 19, 2014 | 09:40 PM
^^ what he said sometimes it works. Worth a shot just retorque in sequence. Just as your replacing the hg start lower torque numbers until you get to where your head is going to be torqued at.
