'02 5.9 No boost.
Old Apr 18, 2014 | 05:32 PM
Fracker's Avatar
Default '02 5.9 No boost.
Any ideas as to why I have no boost,can't find any leaks,tied gate closed,still no good ???
Old Apr 18, 2014 | 08:42 PM
mysterync's Avatar
Hundreds of ideas, from injection pump to map sensor to damaged turbine. Exhaust leaks. Anyone could guess all day. Only way to know is diagnose it and that's not an Internet kinda thing
Sent from my SCH-I605 using Tapatalk 2
Old Apr 18, 2014 | 09:15 PM
Fracker's Avatar
New injection & lift pumps,can't find any leaks,turbine looks good.Map sensor....hmmmm.....thanks.
Old Apr 19, 2014 | 10:24 AM
cupcakefury's Avatar
Mine made low boost for awhile and it was because my valves were loose and stayed open. Just an idea
Old Apr 19, 2014 | 10:28 AM
mysterync's Avatar
If your valves were loose they wouldn't stay open. And while overhead adjustments being off could cause performance issues, if they were loose enough to cause a low boost issue you'd likely be installing a cam and tappets.
Old Apr 19, 2014 | 07:44 PM
Bigg Redd's Avatar
Is this something that gradually happened or all-of-a-sudden?
Old Apr 20, 2014 | 09:09 AM
lilmike1540's Avatar
i would pressure test your system its easy and cheap and you will rule out most causes i did hear about a guy that had his manifold crack and was geting nothing for boost
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
offroad00
24
Oct 23, 2014 03:28 PM
