1993 dodge cummins dosent like starting on hills
Old Apr 18, 2014 | 03:00 AM
Josh Chretien's Avatar
Default 1993 dodge cummins dosent like starting on hills
hey i have a 1993 dodge cummins 12v and it runs great and start cold half a crank and on the flat starts with half a crank... but on hills it likes if you give it abit of gas to fire up or it likes to crank alot to fire up any ideas i have a new lift pump and fuel tank and looks to be a new fuel line from the tank ? thanks for any info
Old Apr 19, 2014 | 06:07 PM
CUMMINStagetcha19's Avatar
So it just doesn't fire right away when on an incline? Does it matter uphill or downhill?
Old Apr 19, 2014 | 08:14 PM
Bigg Redd's Avatar
"looks to be a new fuel line from the tank"......Did you install those new items yourself or did you recently acquire the truck with these items already installed? Sounds like your fuel may be draining/siphoning back into your fuel tank or the like. Check all fuel line connections for leak(s) or loose clamp(s) / connections. Just tossing it out there.
Old Apr 20, 2014 | 12:41 AM
ya i just got the truck not long ago and i put the new lift pump in and the new tank but not the new fuel line. i guess i put newer intjetion lines on as well. so anything fuel like should be checked for leaking like line from tank to pump and the line from the filter to the injet pump and some times when your on hills going slow it likes to stall and then crank and crank but aslong as you give it a bit of gas it wont stall and will start great
Old Apr 21, 2014 | 10:05 AM
Sounds like your calibrated return oriface is weak? Allowing fuel to leak from the pump case, and not getting enough fuel pressure to advance timing to start or stay running well.
Old Apr 21, 2014 | 08:24 PM
and how would i go about fixing that ?
hurriedcoyte
Jun 19, 2015 06:26 AM
rschriek
Feb 3, 2015 10:13 AM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Linkbeltpower
For Sale
Dec 15, 2014 10:52 PM
Nov 4, 2014 08:10 AM
