H1 wheel idea?
Old Apr 17, 2014 | 10:47 PM
SteelRain11C's Avatar
Default H1 wheel idea?
I have a 92 d250 and have been reading every thread on just about every diesel forum I can find about H1 wheels. I like the look of them stock so I was thinking...could I swap in DRW front hubs to basicly make up for the backspacing on the wheel and run spacers on the back? I figure 7" BS minus the 4" HUB is basicly like recentering to 3" BS give or take? Any help would be great
Old Apr 20, 2014 | 06:17 PM
yjay's Avatar
I think this is a better option than running spacers, albeit perhaps more expensive.
There may be cheaper ones/used ones available, but these ones are the standard.
http://www.trailworthyfab.com/Custom-Hummer-Wheels/
I wouldn't run 7" spacers in the rear. I would look into running a dually rear axle without the dually adapters and front dually adapters if you want to run standard backspaced H1 wheels. Dually rears are wider I believe but I'm not sure by how much.
Old Apr 20, 2014 | 06:31 PM
I was never gonna run 7" spacers haha im not that crazy. 4" max since I dont really haul alot. Mostly my daily driver and play truck. I just like the look of h1 wheels that are not recentered. I have a "buddy" that can hook me up with 24bolts with tires for free .99 and im just wanting to swap the front end. To d350 hardware
Old Jul 4, 2014 | 12:57 AM
V Simon's Avatar
you do realize that wheel is not a really good on road wheel there a Pain to ballance and the only thing that keep's air in the tire is a rubber O ring . plus you have to remove up to 24 bolt's just to get wheel apart . there are several places out there that recenter them but IMO there garbage . Just find a reg 16.5 wheel and run the humvee tires .
Old Jul 4, 2014 | 07:46 AM
u2slow's Avatar
My buddy runs H1 tires/wheels on his 2nd gen. He went with 2" spacers on all 4 corners.
I'm going to a Dana 80 in my W250, which is wider. I also got 2" spacers for the front. I will be running 3rd gen wheels (6" backspace) and maybe H1's later.
Old Aug 15, 2014 | 01:27 AM
V Simon's Avatar
the Junk Humvee wheel's are Not DOT approved for the road besides the only thing that keep's air in the tire is a rubber O ring No Thank's
Old Aug 15, 2014 | 06:26 AM
u2slow's Avatar
The ones my buddy has are 24 bolt and have the DOT stamp. They've held air without issue for the year or so he's had them.
Old Aug 15, 2014 | 01:11 PM
yjay's Avatar
The only thing that holds the air in any tire is a thin rubber membrane that relies on pressure to seat the bead. So what? The o ring is captured and I'd say the chance of failure is almost non existent. It acts like a gasket. As far as balancing them, balance beads work well.
And they are DOT approved.
H1 Hummer Wheels
Plus they lock the inner bead as well, unlike the vast majority of beadlocks you see on rock crawler type rigs. Really nice and safe design.
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
