infinity system upgrade
Old Apr 17, 2014 | 12:19 AM
2gCummins's Avatar
Default infinity system upgrade
Hey all! I'm sure this has been discussed before but I haven't found enough information.
First a little background: my drivers door speaker went out and I am pretty sure the infinity amp is shot.
What I want to do is bypass both door amps and install a new deck that will run the door speakers off existing wires.
From what I have gathered is that I can just find the 2 wires going to each door speaker and tie those directly into the new head unit bypassing the amps all together.
Had anyone heard or attempted this? Any help would be appreciated.
Old Apr 17, 2014 | 11:43 PM
lilmike1540's Avatar
Were are the amps mounted you will uave to run wires to the out side on the amp for that to work
Old Apr 17, 2014 | 11:51 PM
2gCummins's Avatar
So just to be clear I would just tap new wires from the speaker to the existing wires going to the deck bypassing the infinity amp all together?
Old Apr 21, 2014 | 04:14 PM
vcustoms86's Avatar
Ive have always been told you would have to rewire the entire system in order to do it properly. Could be the audio shop trying to nickel and dime me too. Makes sense of what you said though. Wire around the amp and cut it out of the system. Good luck
Old Apr 21, 2014 | 07:40 PM
yes you will have to bypass the amp or swap that amp the amp is a powered pass through no power no sound if i were you i would get a four ch amp and run your front and rear preouts to it and run the wires to the speakers from there and get a 30$ amp install kit from walmart if you use a amp it will sound much nicer
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
truckerchuck76
Feb 3, 2015 05:40 PM
Loghomeman
Audio Equipment/Electrical
Oct 25, 2014 08:18 PM
