P-pump conversion problems
Old Apr 16, 2014 | 09:06 PM
can_man's Avatar
Default P-pump conversion problems
hey everyone, I have a p-pumped 24v and I'm having gauge problems, my speedo and tach and fuel gauge, i'm not sure if my fuel gauge is something to do with my fass pump, or sending unit, and i've been trying to figure out if the rest of the problem is my ecm or cam, sensor.
any help or advice is appreciated. thanks
Old Apr 16, 2014 | 10:06 PM
coors_man_2005's Avatar
Is the ecm still in the truck
Old Apr 16, 2014 | 11:12 PM
can_man's Avatar
yea, i relocated it and put a 12 valve front cover on it so i could use the cam postion sensor for my gauges, everything is hooked up and was working.
Old Apr 17, 2014 | 08:15 PM
RedChevy44's Avatar
Did you replace just the front cover? The sensor on the front of the 12 valve covers is a crank position sensor. You need the cam sensor that was under the VP44 for the tach.
Old Apr 17, 2014 | 08:29 PM
can_man's Avatar
I swapped out the sensor for a 12v cam sensor. The local shop here (con artist i think) told me that I had to use a 12v sensor, not the 24v one...
Old Apr 17, 2014 | 11:49 PM
lilmike1540's Avatar
No it you were supossed to make a relocating bracket for it i think you can buy them it just mounts it in a way so you can run a ppump
Old Apr 18, 2014 | 12:36 AM
can_man's Avatar
any idea where i can buy one?
Old Apr 19, 2014 | 11:16 PM
Cummins performenc parts i think has them
Dbleo351
Nov 20, 2016 09:34 AM
Cummins86
Feb 11, 2016 05:24 AM
S_R_H
Jul 28, 2015 11:58 PM
Andrew1995
Wanted To Buy (WTB) - Used
Feb 25, 2015 03:44 PM
moneypitk5
Feb 12, 2015 11:01 AM
