Cut off exhaust tip...how to extend?
Old Apr 14, 2014 | 11:00 AM
bod925's Avatar
Default Cut off exhaust tip...how to extend?
I purchased a truck that the previous owner put a 10" exhaust on by spot welding it (see photo). I want to replace it with something less overkill, like a 6" tip. However the existing tip will need to be cut off due to the spot welding and both are 18" long; thus when I cut off the current tip I will lose about 3" of exhaust pipe. When the new 6" tip bolts on, I want it stick out exactly where the current one is. Not any further in or out. Any ideas how I can "extend" the 5" exhaust pipe that 3"? Only thing I can think of is using a 5" muffler delete pipe and cutting of the length I need. However those are $50+. Thats alot of $$ for a 3" extension...
Old Apr 14, 2014 | 01:00 PM
AHolt's Avatar
Take a hand grinder and grind weld off.
Old Apr 14, 2014 | 01:05 PM
bod925's Avatar
Thanks Aholt, good idea
Old Apr 14, 2014 | 07:53 PM
six speed's Avatar
i agree, grind the welds in two and the tip should comer right off, but if you need a little more length it looks like you might be able to loosen off the u-bolt and maybe gain an inch then tighten it back down.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Poorboyljl
Jun 6, 2015 09:59 AM
Jake12valve
May 10, 2015 11:57 PM
carid
Diesel Bombers Sponsors
Dec 12, 2014 02:26 AM
